Linear parameter distance value rounding
Hi all,
I'm in the process of creating a dynamic tileblock for a landscape architect.  I have set up a linear parameter with distance values that correspond with different sheet sizes (8.5x11, 11x17, 22x34 and 24x36).
My problem is that the correct diagonal distance for the 24x36 sheet is something close to 3' 6 3/4", but Autocad rounds the distance value to the nearest whole inch--and 3'7" is too large.  My dimstyle precision isn't the issue, but I'm totally at a loss here.
Thanks!
ojuris
why did you need diagonal distance?
may be post your block?
dmfrazier
I'm pretty sure this is due to your current UNITS settings.
