Leader with Block, including Block Table
SimonPettitt
Message 1 of 1
SimonPettitt
I have a detail call-out block set up with eight attributes that change based on a block table. The user will come to the template with a spreadsheet of data for their project that can be pasted in to the block table, so they can drop the call-out in the drawing and then select the correct item from the list. This works fine.
I need to have this on the end of a leader - so I've created a Leader style using the block. This inserts fine, but the grip for selecting the item in the table is gone.
Is this expected? Is there a workaround?
Simon
Replies (0)
