Keeping lines parallel when changing angle in block
dbraico
dbraico
I am wondering if there is any workaround for creating a dynamic block that keep lines parallel when adjusting the angle.
I am not the best at explaining but there is a forum here trying the same thing:
https://www.cadtutor.net/forum/topic/61751-dynamic-blocks-rotate-parallel-lines-and-maintain-perpend...
I have attached my version of the block.
I am trying to have the centre maintain the same thickness as the ends if that makes sense.
- thanks
j.palmeL29YX
Attached an attempt using constraints.
If you are not familiar with constraints and need further help let us know ...
Jürgen Palme
dbraico
This is perfect thank you,
I thought it was possible using constraints but I Unfortunately only have AutoCAD LT at my workplace at the moment.
I have been promised a full version which would be great as I make many dynamic blocks.
I appreciate your help very much 🙂
