Keep linear length in annotative block.
h_s_walker
Mentor Mentor
h_s_walker
Ok bit of a weird one.
I want to stretch a line to any length I want in an annotative block, but keep it at that length whatever scale I use.
See the attached drawing for a slightly better explanation.
Howard Walker
Left Handed and Proud
ojuris
try this for idea
h_s_walker
Shouldn't have marked as a solution it's not quite what I want.
I want to insert the block at the correct annotative scale so the horizontal lines "stretch out". The problem is if I then change the annotative scale of the modelspace the block shrinks / grows and the lines move. See the two images below for a before and after explanation.
1:5 Annotation Scale1:5 Annotation Scale1:20 Annotation Scale1:20 Annotation Scale
Howard Walker
ojuris
I don't understand what you actually need
h_s_walker
When I insert the block at a scale eg 1:5. I want the lines to stretch. In my original block (for example) the horizontal line is 15 long. Now at 1:5 scale that line would then become 75 long. Then I will stretch the line to what I need it to be eg 125 Now if I change the annotative scale to 1:20 I want the line to stay  at eg 125 (or whatever I've stretched the line to) and not scale up to 2500 long.
See my images
Howard Walker
ojuris
what block you talking about?
I think in block what I post it was as you need or I don't understand what you need
h_s_walker
The block you posted was sort of getting there. Unfortunately I can't screencast anymore to show you what I want.
I want the whole block to scale up. but if I change any of the distances I want them to stay the same no matter what annotation scale I choose.
Howard Walker
