Justification change on visibility state
jwatkinsJA4W5
jwatkinsJA4W5
I have a dynamic block that I need the ability to add the attribute justification to the lookup table that way I can changed the attribute's justification when the visibility state changes.
Currently I have multiple attributes that the user has to pick the correct one to display correctly for the visibility state.
Libbya
Text justification is not a dynamic property.  You wish as you state it isn't going to happen.
Instead you can add an attribute that with property invisible = yes, but make it 'visible' in all of the visibility states.  Then use a field in your other attributes that reads the invisible attribute's value.
jwatkinsJA4W5
I was hoping the ability to add text justification as an input to the lookup table would be possible.
