It's possible move a position block with tag attribute?
Message 1 of 8
I'm executing a project where i need add blocks at specific coordinates. These blocks represent the position of lampposts.
I have a spreadsheet with the coordinates of all blocks. Is it possible to add an attribute to move all blocks with one command? Or create a lisp? I know that's possible, but i don't how to do it.
Sorry for the English, I'm translating from Portuguese.
Replies (7)
Message 2 of 8
fkp7057
Yes, It is possible.
can I have your coordinates list and block name which are going to use as lamp post?
Message 3 of 8
fkp7057
PFA Excel I have prepared for you here you just need to update X-Y coordinates in Column E & F,
Change Block name in Column D (Replace your block name with S1).
Then copy data that are in the I column (Exclude column header).
Then paste in Column J using  " Past as value".
Then again column J data Just paste in your Script file. the sample Script file is attached here for your reference.
Copy below code and past it in notepad and save as Insert.scr file.
-INSERT
S1 50,45 1  0
S1 30,21 1  0
S1 50,33 1  0
S1 556,54 1  0
S1 44,87 1  0
S1 89,22 1  0
S1 9,25 1  0
In the above code, I have pasted data which are in column J.
after everything is done just drag that Insert.scr file in your AutoCAD window. it will insert block as per your cordinates.
Hope this will help you.
Message 4 of 8
My blocks contain attributes, so when the script add a block the "Edit Attribute" box opens and the script doesn't work well.
After I used a script to insert points at defined coordinates (identical to how you did) and a lisp to exchange the points for blocks. This lisp insert blocks without attributes, finally, i sync attribute for all blocks.
This worked, but it's still a bit of work.
Message 5 of 8
fkp7057
Can I have at least one block or a similar kind of block?
I have tested a block that contains attributes, but it didn't open any edit attributes dialog box.
Maybe a little modification on the script may solve this problem.
Message 6 of 8
 That's the dialog box.
Message 7 of 8
fkp7057
Set Autocad variable "ATTREQ" as 0.
then this dialog box will not appear.
Check Link below
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Enhanc...
Message 8 of 8
Amazing! Thanks to the help!
