Issue with items moving off of basepoint
Colin-Pearson
Colin-Pearson
Hello World.
I've used all the swear words I know and this block still won't behave!
When I use the Move grip and pull this block all the way up, it should extend by 5-7/8" ... instead it extends by 5-3/4" and also moves 1/8" from the Basepoint.  Any clue what's going on here?
Thanks in advance y'all!!!
Libbya
@Colin-Pearson wrote:
Hello World.
Yes, I see what is going on.  It has nothing at all to do with the dynamic linear parameter, move action, or base point.  When you move the grip it DOES extend 5-7/8".  The part that does not move simply does not move.  It does not 'move 1/8" from the base point'.   It is drawn 1/8" from the basepoint.  Fix the way the non-moving part is drawn in block editor and it will work the way you want it to.
Colin-Pearson
you are so right, thank you man.  Sorry about the false alarm.
