issue with Chained Actions for text attribute on rotation
tomhY595S
tomhY595S
Hi, I've found this post - https://forums.autodesk.com/t5/dynamic-blocks-forum/dynamic-blocks-how-to-keep-attributes-horizontal... that I want to replicate for one of our blocks. Essentially want to rotate the electrical symbol keeping the text readable in the same direction.
  • I've used mtext + the shape.
  • added the point parameter + Move action + Chained set to Yes + Removed grip
  • added a rotate parameter + rotate action and included the point parameter
It works correctly as it rotates and keeps text orientated in the right way. However, the issue is the placement of the text on the rotation when the rotation is in N/S/E/W positions in some looks ok and in others, the text is moved a great distance away or overlaps the shape.  screencast - https://share.getcloudapp.com/BluGYG51
Block also attached
Any help would be greatly appreciated.
h_s_walker
Your point parameter was somehow messing up. So I deleted it and put in a new one.
I've made a few minor changes to your block. I've made the insertion point of the text middle center. I've also moved it up a bit so that when it rotates it stays outside the triangle.
See the attached drawing
Howard Walker
Left Handed and Proud
tomhY595S
Thanks very much, hwalker, so essentially in future it's best to keep the point parameter and the text centre aligned in all cases so that it performs the rotation in this manner?
h_s_walker
Yes I would keep them centre aligned, because using the other alignments will make the text "move" over the triangle which you obviously don't want to happen.
Howard Walker
