is it possible to change user parameters from a property lookup table?
barronro
barronro
Community Visitor
Community Visitor
I have a block for a pipe fitting where the client would like to specify the inner diameter and wall thickness. However, the drawing needs only to contain the outer diameter of the pipe.
The simplest and least resource intensive solution is to have the outer diameter length be a function of user parameters for inner diameter and wall thickness. However I cannot find an option to add a slider or dropdown lookup action to change inner diameter and wall thickness; the user has to edit the diameter from the properties table. This is not ideal.
is there an option I am missing to add user parameters to a look up table?
Libbya
Post the block.
No you can't use user parameters in lookups.
Depending on how the values are related, you could add gripless linear parameters or the like in place of any user parameters. It is very likely that would work for your block, but I cannot say for certain unless I can actually look at the block.
