Inserting Electrical Blocks - Break the line or wipeout?
Hello All,
I work in the electrical design field and I am creating new blocks for the company I work for.
Whatever standard I create, will be the standard. These will all be brand new blocks.
My query is, when developing blocks to be inserted onto lines, which would be a better method:
1) Create a wipeout in the block, so it automatically hides the line behind it.
2) Utilize a LISP routine to automatically "break" the line when inserting a block.
or
3) Do nothing at all, manually break the lines.
Has anyone seen an advantage with one over the other?
Thanks in advance
Libbya
If there is not other linework/text that must not be hidden, I would opt for the wipeout.  If there is, then I would trim whatever lines need to go away.  You could make the blocks have a non-plotting boundary within them to make accurate trimming easy.
MMcCall402
After the trimming the block and trimmed linework could be moved along the line with the Stretch command.
I see there is a Trim command and a BTrim command.  I'm not quite sure what the difference is other than the BTrim copies linework out of the block to use for trimming and then leaves it behind.
Mark Mccall
CAD Mangler
VHB - Vanasse Hangen Brustlin, Inc.
Linkedin
Thank you both for your replies
