How to set angular range not starting from 0?
slava-l
Message 1 of 8
slava-l
I encountered a problem when setting the angular range: if the first digit is not 0, AutoCAD gives strange numbers after entering instead of the required values. The values should divide the circle vertically — [90,270] и (271,89).
Before ENTERBefore ENTER
After ENTERAfter ENTER
Replies (7)
Message 2 of 8
j.palmeL29YX
Split the line (270,89) to two lines:
(270,359) and
[0,89)
and fill the right side (Lookup Properties) of course twice the same value
Try if that helps.
Jürgen Palme
Message 3 of 8
slava-l
Didn't help. (270,359) doesn't start with 0. Any first digit other than 0 causes this problem... Does it work differently for you?
Message 4 of 8
j.palmeL29YX
Not here.
I'm not sure if I modifie the right table(?).
Result:
It becomes problematic if you want to exceed the value 0, e.g. from 350...(0)...20. Which is why I would recommend the 2 lines.
Jürgen Palme
Message 5 of 8
slava-l
The table is correct. It seems to me that the problem is not in the number of lines... I have Civil 3D 2025.
Can you attach a file?
Message 6 of 8
j.palmeL29YX
Attached what I did in Vanilla AutoCAD 2026.0.1.
I don't have access to Map, so I can neither test nor confirm what you're reclaiming about.
Jürgen Palme
Message 7 of 8
slava-l
I unchecked the "clockwise" in "units" and copied the text from your file to my file and the problem was solved
Message 8 of 8
j.palmeL29YX
Thank you for sharing this solution.
Jürgen Palme
