How to create a lookup parameter
mbickelVMG55
Message 1 of 10
mbickelVMG55
Can anyone explain to me how to build a lookup parameter and lookup table from scratch in a dynamic block? The parameter type does not appear on the menu of dynamic block parameters. However, when I attempt to create a lookup action, I must select a "lookup parameter".
Autocad help only tells me all the great things I can do with a lookup table, or how to edit it by selecting it, or how to modify the lookup action. But I can't do any of that until I create the table and the parameter, and even google can't help me find out how to do this. Please help.
Please don't ask for an example of my drawing, because it is just a dynamic block WITHOUT a lookup parameter.
Michael
Replies (9)
Message 2 of 10
h_s_walker
Scroll all the way down to the bottom of PARAMETER SETS and you'll find it there under VISIBILITY SET. See the image below
Howard Walker
Left Handed and Proud
Message 3 of 10
Libbya
Here are a variety of ways to make a lookup parameter.  If a lookup does not have any table associated with it, if you double-click it, then a table will be added.  With a table added, double-click the table to enter the editing mode.  Add whatever input or lookup properties you want and fill out with the appropriate values.  See screencast:
Message 4 of 10
mbickelVMG55
hwalker and Libbya,
Thank you both for your help. You have both answered my question, but... unfortunately the answer does not solve my problem.
I am trying to create a simple transform that would add a leading zero in front of integers from 1-9. (as in, 01, 02, etc.). The attached help screen led me to believe I could do this, if I could pass a computed integer through a lookup table. But apparently attributes can't be referenced; only parameters can. And it seems parameters can't have computations. If anyone has any insight into this, or if there are better answers under another topic, please let me know.
It seems that the screenshot references another type of table that must be updated manually. My transform must be automatic; however a manual overwrite option would be good also.
Message 5 of 10
h_s_walker
Post your drawing so we can have a look. Then we can suggest a workaround
Howard Walker
Message 6 of 10
mbickelVMG55
I will accept your solutions and start a new thread when I can.
Message 7 of 10
Libbya
You might potentially be able to add a second attribute, add a field that references the first attribute value and format the value to have your leading zero.  Hard to tell if that would work without seeing the block.
Message 8 of 10
mbickelVMG55
This is a very simple block that puts a matchline refererence to other sheets. My company references sheet numbers through the sheet title (system variable ctab). The desired text simply adds or subracts a number from ctab. That part is easy.
I have tried many workarounds. The most frustrating part is that autocad has options for formatting the output. There are hundreds of possibilities simply with the formatting. But the closest I have found is to divide by 10 and make the decimal delimeter a space. That leaves a space in the numbers (0 1, 0 2, etc.).
I have had success with property sets. However, they can only be referenced in labels that appear in model space. I have solved this problem where plan production matchlines can be used. But for our biggest client, I need a dumber matchline in paper space.
Referencing another attribute could possibly work, but I believe that may need a nested block, which could lock the variable to a constant...? If there is syntax to reference another attribute int he same block, I would like to know. It is possible to reference it in an instance of the block, but might be too complicated for some of my users.
Message 9 of 10
Libbya
Did you intend to attach a block?
Message 10 of 10
mbickelVMG55
I have posted a block in a new topic. Thanks,
