How do I change the hatch boundary in a dynamic block?
jim3thornton
jim3thornton
I have a 7'-4" w X 8'-0" h roll up door BLOCK.
With changing site conditions, I want to convert this static block in a dynamic block.
The perimeter is a rectangle with a hatch pattern representing the horizontal slats.
I am able to assign the stretch action to the rectangle, but the hatch pattern does not increase in height.
Instead the hatch pattern moves upward with the stretch.
I have tried changing the hatch pattern to associative through the block editor, but that command is null.
Is there something I am missing is this process?
I know I can use the ArrayRec Command with multiples of a horizontal lines, but I have not tested it in a dynamic block.
I am presuming there is another way to introduce additional horizontal lines as the height increases, but I have not found that command yet.
Any input would be helpful.
thank you
Libbya
Remake the hatch pattern as associative from the start.  The stretch the hatch boundary (making sure it stays closed) and do *not* stretch the hatch.  Post your specific block for more pertinent assistance.
