@paliitali wrote:
is it possible to move the length grip to the center of the circle
In the center of the circle you whish 2 grips? One grip to drive the lenght of the horizontal part and a second grip to drive the lenght of the obliqued leg? That would lead to a lot of new problems - but I'm not sure if I understand you right.
is it possible ... the 0,0 set to the center of the circle
Doesn't make sense for me. How would you now dynamically change the dimensions, where do you want to place which grips? In the center of the circle you want 2 grips to drive several lengths and now additional here you want to be the basepoint (0,0) of the block? I'm confused ...
is it possible to make this block work with action parameters
I didn't yet try it for the complete block. Actually your block contains Dynamic Parameters and Actions beside Parametric constraints. (BTW: It is not a good idea to mix dynamic parameters/actions with constraints anyway, i.e. to use both methods side by side.). My first attempt above (post #2) solves the question "Force the arcs to trim when the angle is changed" using constraints. The next attempt (post #8) shows how you can solve this partial problem without of constraints. I was not yet aware of additional requests (nested block).
It appears difficult to get everything to work correctly, especially with with a nested block.
It is difficult to keep up with your ever-changing demands and wishes. Especially when the meaning behind it is not recognizable to an outsider (or at least not to me). Wouldn't it be possible at first only to describe the intended functionality of the block: what should it be able to do, which dimensions should be changed, where handles are required or desired, perhaps which values may be changed without a handle (i.e. only via the properties window), where should be the base point (it is only for moving the whole block reference) and so on? And tell us ALL what you need/whish. With every new claim we start all over again.
With knowledge of the intended goal and the overall functionality of the block, it would be easier to help (or to say what is not possible)
Jürgen Palme
