Help with dynamic block
Sujan.Maharjan
Message 1 of 14
Sujan.Maharjan
I'm trying to make a block. I described my problem inside the dwg file I'm attaching here. Please suggest me appropriate solution
"Revit Lies in the tension between what we want to do and what can be done!"
Replies (13)
Message 2 of 14
ojuris
you must use 2 linear parameters and 2 array actions
Message 3 of 14
Sujan.Maharjan
Thanks @ojuris .Any other suggestion for these two?
Message 4 of 14
ojuris
Could you repeat that situation with block what I post?
Or I don't understand something
Message 5 of 14
Sujan.Maharjan
Hi ojuris,
When I make the block very small an extra piece left behind. How to get rid of that without having to change visibility state?
Message 6 of 14
Libbya
Using visibility states is the way to do it, but you can make it automatic using a double lookup.  See screencast:
Message 7 of 14
Sujan.Maharjan
What about turning on off something attached to it?
Message 8 of 14
Libbya
I don't quite understand your question.  Please give more details on what you are asking.
Message 9 of 14
Sujan.Maharjan
That 'M' is optional. Maintaining the same Linear parameter can i have a visibility grip to turn it on or off with same double lookup setup?
Message 10 of 14
Libbya
Yes, you can, but it gets a bit complicated.  This screencast picks up where the other left off except I added the line/box/M.
Message 11 of 14
Sujan.Maharjan
Hello there, Can you please help me understand about the function of Point Parameter here?
Message 12 of 14
Libbya
It is 'memory'.  Its position is switched between 1 and 0 when the 'M' is turned ON and OFF.  It is then used as Input in the double-lookup Input table in order to determine which visibility state is shown by the Output table of the double-lookup.
Message 13 of 14
Sujan.Maharjan
I tried to move the point with Flip/Rotate/move to x=0 but didn't work. Why?
Message 14 of 14
Libbya
I don't know what you're asking.  Maybe post the block with a more in depth explanation of the issue.
