Help with 1st parametric block
robert.webster247M7
robert.webster247M7
Hello.
If someone could spot why i am having issues with my 1st proper parametric block, I would be very grateful!
After I have inserted the block, i copy it. Should I then alter the rotation parameter on the original insert or one of the copies, the geometry rotates, but the parameter value in all but the 1 that I selected to change, remains unchanged.
If i open one of the affected instances reset the dynamic property ( if needed) and save the block, all the blocks are fine and work independently as intended.
If i copy again, the problem arises again in those in the new selection set.
j.palmeL29YX
A mix of constraints and dynamic parameters/actions mostly will cause problems.
In your block I deleted the rotation parameter and action and substituted by an Angular Constraint Parameter. (And also added some other constraints to stable the geometry). Now I can't see any problems.
Jürgen Palme
robert.webster247M7
Thank you very much Jürgen.
