Help Stretching multiple objects keeping centered.
I have this 6 panel door i would like to stretch horizontally and vertically but cant keep them looking right. here is an attachment
Libbya
The solution is the same as your other window blocks.  The horizontal stretch would require two stretch actions, one with a distance modifier of 1 and the other with a distance modifier of 0.5 to keep the middle parts centered.  You would need to give specifics about how you want the height stretched.  I imagine the handle would remain at the same height.  The top would stretch with a distance multiplier of 1.  I'm not sure how you would want that top horizontal to stretch.  Do you want the top panels to remain a consistant size?  Do you want the same proportional distance from handle to horizontal to top of door?
Well the panels can increase in length the door panel would stay where it
is. I guess it cud be okay for just the top two panels to increase length
got it working thanks
Libbya
Here's a screencast that shows the step-by-step for keeping the divisions proportional during a vertical stretch.  The concept is the same with a different stretch action with a different distance modifier for each area that stretches at a different rate.
