Help please on multiple visability states
Dee_Baylis
Observer Observer
Dee_Baylis
Observer
Observer
I'm hoping someone can assist me with this.
I'm working on a dynamic block that includes the following:
  • Visibility Parameter 1: Fire rating (EI30, EI60, EI90)
  • Visibility Parameter 2: Profile selector
  • EI30 and EI60 → Profiles 1–4
  • EI90 → Profiles 1–2
The goal is to display only the valid profiles based on the selected fire rating.
I've followed a tutorial and created the block as far as I could, but I'm running into an issue:
When EI90 is selected, all four profiles appear. However, profiles 1 and 2 (34mm) are incorrect for EI90 — only profiles 3 and 4 (56mm & 109mm) should be shown.
How can I remove the two invalid profiles for EI90?
CAD file is attached
K_Kubat
This type of visibility isn't actually needed for this block. A block table would suffice.
Dee_Baylis
Observer
Observer
Thanks for your help. Much appreciated.
