HELP.... Paremeter is moving instead of stretching.
pete592
pete592
On the attached damper block, I am trying to get the blades to array when the damper width is increased.
I have the distance parameters for the arrays chained to the damper width actions, but it's not working and I cannot for the life of me figure out why.    Thanks in advance for any help.
Libbya
You should never place the base point parameter anywhere other than 0,0 within the block definition.  Adjust the rest of the block as necessary for the base point to be at 0,0.  There is no reason for a base point parameter unless you need to dynamically move the base point in relation to other items within the block definition.  That is not the case here so it is not needed or helpful and can cause problems especially with chained parameters/actions.
I am not sure why your stretches were not working.  Sometimes if you move or stretch a stretch action while working in block editor, the selection set needs to be redone.  The fixes it in this case.
pete592
Excellent. Thank you so much for the help.
