Hatch behavior in block
EvtimovD
Message 1 of 8
EvtimovD
Hello community,
i would need some help from more expierenced users then me:
I have created a dym. block with a hatch inside the polyline.The block is scaled to meters, and if the sides extend a value of 7m, the hatch turn from solid to the line thingy...
May you please have a look?
Greetings Dimi
Accepted solutions (3)
Replies (7)
Message 2 of 8
h_s_walker
You're using the ANGLE pattern. Change it to SOLID. See the image below.
Howard Walker
Left Handed and Proud
Message 3 of 8
EvtimovD
thank you very much for the wuick help.
I am still ab bit confused, i dont see the hatch in the block editor, nor i can select it with hatchedit.
I guess i am doing something wrong...
Message 4 of 8
h_s_walker
Go into the block and use QUICK SELECT. You can either right click and choose SELECT from the menu or type QUICKSELECT at the command line. See the image below
Howard Walker
Message 5 of 8
EvtimovD
Thank you very much.
I will look into my seetings, there ist noc quickselect command for me.
Message 6 of 8
h_s_walker
Does your right click menu look like the one in the image below?
Howard Walker
Message 7 of 8
EvtimovD
Hello hwalker,
yes i have the same right click menu, but unfortunately no quickselect in the command line.
I have managed to change the properties of the hatch to solid, and the problem is solved.
I will seatch in the aliasedit for the quickselect or try to add one.
Thank you very much for your time and effort.
Greetings Dimi
Message 8 of 8
EvtimovD
All right,
found it:
qselect is the command, which is kinda obvious... my bad.
