Flat Duct Bend Dynamic Block Scale Problem
jamie_lovelock
jamie_lovelock
I'm trying to create a dynamic block which is a flat duct bend. I almost had no problems creating the block except the outside line.
The outside line needs to be 20mm away from the bend itself (which represents insulation) no matter what I do, I cannot figure out how to scale it but also keep it 20mm away from the bend. I originally thought that I could do it with an angular dimension so as I stretch or scale the block the dimension would follow it. It needs to stretch/scale from the center of the block outwards
I've tried using constraints but I've found they are incredibly buggy. Does anyone have any ideas on how to do this?
h_s_walker
Check my reply in the link below
Re: Any way to keep linework a fixed distance apart? - Autodesk Community - AutoCAD
Howard Walker
Left Handed and Proud
Libbya
jamie_lovelock
It was really that simple!
Thanks a lot for your input!
