Hi I'm trying to merge two methods
- Array of a containing block
- Visibility Lookup table
In order to create a block that can be increased in size and subsequently show more attributes or less according to the requirements. Attached is the block which is essentially a floor finish legend container. With multi-line attribute text on the right, an empty box (that will later be hatched by the user) I want to keep it simple so just the 1 grip point that creates the array and hides/shows the visibility states.
Tried to merge what I've learned in this post - https://forums.autodesk.com/t5/dynamic-blocks-forum/issue-with-visibility-state-of-attribute-blocks/...
and something I've stumbled on, on this post - https://forums.autodesk.com/t5/autocad-forum/array-attributes-with-dynamic-blocks/m-p/2757177#M25219...
There are at least 2 issues with the block that I can see
1) Mainly how to link the visibility state to the grip point
2) When the array is active after the 2nd /3rd array the grip detaches from the current array.
Any help would be appreciated.
screencast - https://share.getcloudapp.com/6quzej7p
Best
Tom
