I have hit an absolute BRICK WALL on a very important, complicated dynamic block project.
In the attached dwg is a conveyor bed that is designed to be stretched from 3” long to 72” long.
There are two basic Visibility States for the user to select: a lightweight and a High Detail
As you can see in the top (High Detail), I can array components just fine. I did NOT chain ANY parameters together in order to have the top High-Detail configuration cooperate
HOWEVER...
The 2nd row is the Lightweight Visual State. Whenever I try to assign the blue rectangles (O-Bands) from that state to the array that controls the rectangle O-Bands for the High Detail state, the Lightweight O-Bands will disappear, so I don’t have them assigned to ANY parameter here.
The third row is my attempt to build a very basic, brand-new construct of the LightWeight visual state to try and examine the array issue without anything else going on. I cannot get the blue rectangle in that block to array AT ALL. It needs to repeat for every 6” that the block is stretched.
Can someone help me understand why the array action in the bottom basic-block construct is UTTERLY failing?
Feel free to open the test2 block if you like but I’ll warn you ahead of time, it is SUPER complicated. Thanks in advance for any help!
