Extraction of Data to excel from cad file
Message 1 of 10
Dear Experts
I would like to ask that :
Is there a way to get the attribution information for the layer (M-H  ,  M-H-Text) , (L-text)..
I want from M-H-Text layer in excel : Easting , Northing , I.L , G.L & MH
I want from the same for L-Text layer with generated E & N at that location with the information : Diamter , Slope and material
Any suggestion and guidance Highly appreciated
Replies (9)
Message 2 of 10
vinodkl
@Anonymous wrote:
Dear Experts
What do you mean by "attribution information of the layer"? cause I have never heard one before. Can you explain more about this?
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 3 of 10
I mean just the information related to that
Red Colour Text is for M-H  ,  M-H-Text layer details
Blue colour text is for L-text
Message 4 of 10
vinodkl
what I could see from the screenshot is that you are working on AutoCAD MAP 3D and you have posted the question in plain AutoCAD forum.
Here is link for AutoCAD MAP 3D forum : https://forums.autodesk.com/t5/autocad-map-3d/ct-p/72?_ga=2.115582470.1489388640.1578285731-16847915...
Post you question here they will be able to help you out.
Message 5 of 10
Dear
Its autocad 2016 version brother , Kindly check
Message 6 of 10
vinodkl
what you are working on is a AutoCAD vertical which is AutoCAD MAP 3D.
This forum is only for plain AutoCAD not AutoCAD MAP 3D
This is how it looks when opened with plain AutoCAD as plain AutoCAD doesn't recognize objects created with AutoCAD verticals
Message 7 of 10
Apologies , It was my mistake , It was from the colleague and with due respect we are working with autocad only
Please find the screenshot attached
My query is to extract the information which is in text in the highlighted layer with easting and northing..
Your guidance highly appreciated
Message 8 of 10
ilia.borisov
Try command EATTEXT
Message 9 of 10
Using the Above command it doesnt extract the information which is required
Message 10 of 10
ilia.borisov
Freeze all layers, unfreeze only desired layer copy objects in new file and then use EATTEXT then repeat for the next layer.
