EXTEND ANGLED SECTION WITH MIRROR
dbraico
dbraico
I am wondering if there is a fix for this issue I have when mirroring (flipping) this dynamic block.
the angle is set at 9DEG and i have the 'EXTEND' parameter to extend this at the correct angle and length by amending the stretch action 'Distance multiplier' and "Angle offset' for this angle.
when the block is flipped however, it doesn't flip the stretch action and would like to know if there is a fix or better way to do this so that the EXTEND parameter works when flipped.
Hopefully this makes send when using the block
Many thanks
Libbya
Set BACTIONBARMODE to 0 and then add the stretch action with the angle offset you would like to flip to the selection set of the flip action.
dbraico
Thank you so much for this solution.
