Exploding Dynamic Blocks
dbrblg
dbrblg
This one has been bugging me for a while... how can I explode a dynamic block maintaining the dynamic elements. So for example I have a block in a drawing with some dynamic element, say visibility parameter. I don't want the block in the drawing as a block but the exploded version (lines, attributes etc) so that when I insert it in to another drawing (AutoCAD Electrical) the inserted drawing is the block otherwise there it becomes a block within a block and the attributes are not updated. So I want to explode the block and have the visibility parameter move up in to the drawing from the block. Is there any way to do this? I have blocks with dynamic elements which I don't want to have to recreate again in the drawing after I've exploded my blocks...
MMcCall402
Open the dynamic block in the block editor, save as, and save block definition to drawing file. This will save the block with all its dynamic features as its own drawing file.
Mark Mccall
CAD Mangler
VHB - Engineering, Inc.
dbrblg
Yep, thats done the trick Smiley Very Happy
Thanks very much.
gak19043
How exactly, while you're in the Block editor, do I do a "Save as"? I don't see that option there while in blockeditor.
If I go to the "normal" save as, while still in the block editor,  then it 's asking to save the whole drawing I am in as a dwg file. Can you please clarify the exact steps while in the Block. editor?
h_s_walker
Click on the white arrow (ringed in red in the first image) and then you can choose save as (ringed in red in the second image)
Howard Walker
Left Handed and Proud
gak19043
Slap to the forehead, thanks. I'm just an idiot sometimes :). Thanks!!
