Exclamation Mark on Dynamic Block
fjolis
fjolis
Good day,
I have a weird issue where all my linear parameters suddenly showed up with an exclamation mark. I turned off annomonitor, but it doesn't disappear. I've also read other articles about this and what was recommended was to remove the parameter and redo the whole thing. The problem is, I already made multiple blocks that work (including the one in the snip). There are no other issue except for this exclamation mark. It's also not really showing me what the error is and how to fix it. All these linear parameters have stretch functions assigned to them. Everything works, but when I try to do some maintenance to the block, it says something like "autocad document has a command in progress".
Thank you
Libbya
The error is there because you have a grip turned on for that parameter without any action associated with the grip point.  You might be able to eliminate the error by setting the grips to 1.  That will not work if you created the linear parameter "backwards" and have the actions associated with the base point location of the parameter rather than the end point.  Does that explain it all well enough?
fjolis
Makes sense! It works now!
Thank you
