Ellipse
Ellipse
Cez
Message 1 of 10
Ellipse
Cez
another question: P
it is possible that AutoCAD makes an ellipse on the basis of 2 contraint parameter (Length x Width)
thanks!!
Replies (9)
Message 2 of 10
I'm trying to constrain an ellipse arc and it doesn't appear to be possible. Just bumped my thread if you want to subscribe to the sounds of silence.
Message 3 of 10
Cez
thanks for trying!!! hopefully someone else nows how !
Message 4 of 10
terence
Community Visitor
Community Visitor
make a rectangle, click to highlight, right click for menu-select polyline then spline fit
hope that's what you want...
Message 5 of 10
Cez
Not really! sorry,Smiley Wink
I find it strange that theres a diverence between the side of the arc and the original rectangel, and he is not making a ellipse, it is rounder.
I also can not define the WxL with a parameter.
Thanks for your helpSmiley Happy
Message 6 of 10
Libbya
Attached might be what you are looking for.  It does not use constraints, though, but rather dynamic parameters/actions.
Message 7 of 10
Cez
I think this is the solution and will try it too fixenik in my block ... you keep up to date.
good work and thank you for your work.
Message 8 of 10
Cez
Is it also possible to do this with constrains?The width and height is a result of a calculation in my block and this is the only possible with constrains.
If i only know how to get a quarter of the ellipse with the "3 points" to attatch a stretch action.
I hope you can help me.
Message 9 of 10
Libbya
Can you post the block?
Message 10 of 10
Charles_Shade
To your point all Circles can be Ellipses  but all Ellipses are not circles; just think that the Major and Minor Radii are the same hence a circle.
But even though to the eye it may look Circular if the Major axis is X and the Minor Axis is X-.0001 (whatever) then technically it is an ellipse.
