Dynamic Blocks Forum
Elevation Symbol
1 REPLY 1
SLloydBowen
2108 Views, 1 Reply
Elevation Symbol
I have two symbols used for elevations; interior and exterior.  I have been trying to combine them into a single block while maintaining all functionality without the need to double the number of attributes.  I have managed to get the sheet number attribute to change locations as required when switching from interior to exterior.  I have the view direction arrow rotating as desired.  The view identifier attribute rotates as desired.  What I cannot seem to figure out is how to make the view identifier ignore the rotation angle and move to the desired location when the symbol type changed from interior to exterior.
I have included a drawing that shows four examples of how the exterior symbol and the interior symbol should work.  I also included the block as it is right now.  Any suggestions would be appreciated.
1 REPLY 1
hwalker
in reply to: SLloydBowen
Personally I would put another attribute in for the exterior.
Then if you want to extract the data for any reason you can differentiate between interior and exterior elevations
Howard Walker
Left Handed and Proud
Forma Design Contest
