Dynblck Elevation with door + glass wall
Hello!
We do a lot of elevation drawing due to the product we sell & build. We're looking into Revit/BIMobject, but for now we're using AutoCAD LT. I've figured out as you can see in the attached dwg how to create different selectable widths for the door part. Now I would like the glass part to generate glass partions depending on the width and they shall all have the same width as displayed in the attached image/PDF. Due to weight limitations we've to stick to a certain width and instead add more glass partitions., my guess is that you've to incorporate some kind of invisible layer state.
Is this possible with AutoCAD LT or do we need the full version.
I'm also looking for tips if it's possible to create our grid design glass wall with dynamic blocks?
/ Cheers!
ojuris
try attached file
Thanks! But is it possible to have more glass partitions appear when you exceed 900mm in width of each glass?
Also for square wall, instead of increment increase is it possible that each of the squares has the same width and height and adjust accordingly when the width and height changes?
