Dynamic Stretch + Array that maintains a gap distance.
jsf025
jsf025
Greetings,
 I was wondering if there is a way to dynamically update the column offset in the array action or a way to mimic that behavior?
 To clarify why I would want that, I'm trying to create a mirrored linear stretch on a shape with an array  that will maintain a .5 gap between the arrayed shapes and the original. My hope is to maintain the .5 gap regardless of what I stretch the original dimensions to.
 I realize this is likely achievable if I were to create a bunch of versions of the shape and simply toggle visibility with a lookup/double lookup, but that would be time consuming and defeat the purpose of the block (to save time and have the array do all the work).
Any help is appreciated.
Libbya
You cannot dynamically change the column offset of a dynamic array action.  Because of this, if you use a dynamic array, this concept is a non-starter.  You might be able to use an actual Autocad ARRAY object and control it dynamically using constraints and formulae, but that is a complicated enough process that I'll opt out of assisting.
