So i have created a dynamic block of 140x50mm timber stud, which I would like to be able to stretch to array and appear at 600mm c/c. The problem is if i want to pull the array arrow from the initial distance to 600 the second stud does not appear. In order to make it appear i have to pull the arrow/change the array distance to the next distance so 1200 and if i want 2 extra ones then I have to change it to 1800 etc.
The initial array distance is from the "left side" to its centre (so 25mm), so the parameters minimal distance is set to 25mm, with 600mm increment. The array action is set to 600mm as well.
Does anyone know why is the array not working properly and how do i solve that?
