Dynamic door block - problem with flipping
MichalHakel_SP
MichalHakel_SP
I created dynamic block for door. I added 2 flip actions - "In/Out "and "Right/Left".
It works good till I use linear stretch of the door.
When I do it, flipping through vertical axis doesn ´t work well as you can see in the video I attached.
I also attached .dwg file with the dynamic door block.
Where did I make a mistake please ?
Thanks to each of you for the help in advance.😉
MichalHakel_SP
I apologize. I just found out how to solve this.
It was only necessary to add the flip parameter to flip action in the same direction and value as the attribute is flipping.
