Dynamic Blocks
Dynamic Blocks
Dynamic Blocks
I am trying to create a dynamic block that will show me level in the Y axis
j.palmeL29YX
IMO you don't need a Dynamic Block.
- Create a standard block
- in the Block Editor add an Attribute Definition
- in the field "Default" pick the right button "Insert Field"
- choose in the Field Names list "BlockPlaceholder"
- choose in the Block reference property list "Position"
- at the right deselect the buttons X and Z
- choose any Format if necessary
- close the blockeditor and save the block
An example you find attached. Move a block anywhere. after a Regen the value will be updated.
If this is not what you are looking for we need some more informations what you want to do / to get.
BTW: "Dynamic Block" is a very useless subject for a new thread in the Dynamic Block forum.
cadder
Jürgen Palme
Thank you for your reply.
This isn't what I was looking for. I work in the construction industry and was hoping to create a dynamic block that would show floor levels with out manually typing value in.
j.palmeL29YX
Show us an example what you expect.
cadder
Jürgen Palme
Hi see attached
I'm looking for the block to change height i.e. Ground level 0.000 to change to eaves height 6.190
j.palmeL29YX
@Anonymous  schrieb:
Hi see attached
No attachment here.
cadder
Jürgen Palme
I finally got it sorted. Thank you for your help
