Hi Guys,
I'm trying to create a dynamic block for wood screws and I'm having trouble using multiple lookups to force stretch action to match desired visibility.
I have 8g, 10g and 12g Screws and I want only one visibility to switch between gauge and for each gauge I need one grip to change the length of the screw.
I've created visibility for all the different sizes and tried to use lookups to relate the stretch with the visibility (I've made this because the screws don't have a consistent geometric when stretched).
If I delete lookups for 10g and 12g and leave only the lookup for 8g, it works. When I have more than one, the stretch grips simply disappear.
Perhaps there is a different method to do this but I got stuck.
The drawing is attached, thanks for the support in advance.
Sizes:
