Dynamic blocks with different "x" and "y" values
I created a dynamic block of a section view of a storm drain clean-out box with two parameters. One to stretch in the "x" direction and one to stretch in the "y" direction. If I insert the block with a "x scale of 1" and a "y scale of 2", I lose the dynamic parameters... Is there a way to fix it so I don't lose those parameters?
timothy_crouse
It works correctly for me.
Are you sure you not inserting the nested version you posed?
Here is is in a form you can insert and find that it works.
Timothy... thank you for the response... if you look at the properties of the two blocks shown in the drawing I posted, you will see they are the same block with just a different "y" scale... the block with the "y" scale of 2 does not show any dynamic links. if you change the y scale back to one, the links show back up. is there a way to have dynamic links if the block is not a uniform scale?
Libbya
No.  Quite simply Dynamic Blocks lose dynamic function unless they have a uniform scale.
timothy_crouse
I understand now.
You could get a bit creative with the dynamic functions and stretch the Y twice the X with a single linear control.
Or use a lookup table to enter the values.
Was the goal of the Twice the Y scale on an insert operation for speed and simplicity or was there a bit more to it?
Are the sizes pretty standard or is this to be a universal fit?
Best Regards
-Tim C.
