dynamic blocks flip parameter
teenager72
teenager72
hi
i've created a door dyn block. when i stretch it, the flip parameter stays in position and doesn't move to the middle of the door. is there any way to solve that?
Libbya
Add a move action to the same parameter.  Add the flip to the move action's selection set.  Set the move action's distance multiplier to 0.5 in properties.
ian.mag
Hey @teenager72
Instead of the stretch, why not adopt the dimensional constrain parameters? You may then use the construction geometry as the reference for the flip action.
Libbya
Mixing dimensional constraints with dynamic parameters/actions is generally a bad idea and one of the most common causes of problems posted on this forum.
