Dynamic blocks, editing text, chart, table
I´d like to edit dynamic block with attributes. It is chart and I would love to make my chart smaller or taller but I want it to be editable at the same time. So I wanted to copy two attributes I have already put in through the chart and then edit every line one by one and write in different text every time.
I think there is already this stuff explained but I am not able to find it.
Thx for you help.
timothy_crouse
I think you would have to have ALL the cells in the table to begin.  Then use visibility states to set the X/Y qty of visible cells.
The beauty of this approach is that when you double click to edit the table only the cells visible will appear in the list to be edited.
If you are looking for a way to create attributes "on the fly" you would have to look into a lisp or visual basic function as you cannot array attributes.
-Tim C.
