Dynamic Blocks can be edit in the tool palette?
joe-2020
joe-2020
My question is: Is it possible to edit AutoCAD's default 'Dynamic Blocks' from the Tool Palette, in the Block Editor and then save them?
When I try to save the edited dynamic blocks under a new name and insert the 'new' edited block in the tool palette, it won't update.
AutoCAD seems to be preventing me from editing and saving default blocks. A message says that the drawing is 'File Protected'.
Is there a way around this?
vinodkl
Check if your tool palette is write protected. You will be able to see a lock symbol at the end of the tool palette saying its "write protected". You won't be able to modify or add new symbols to the tool palette in such case.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
