Dynamic block
Dynamic block
suryaprakash1
Dynamic block
suryaprakash1
Community Visitor
Community Visitor
Thanks in advance for all your support.
I have a question about dynamic blocks because I'm not sure how to handle the following issue.
Whereas the entire width of the bridge shouldn't be greater than 5000 meters, the minimum and maximum distances from the centerline on the left and right sides, respectively, are 1297 and 3306 meters.
For example, if we stretch the bridge to a maximum length of 3306mm on the left side, the width of the bridge on the right side should not exceed 1694mm.
The entire width is 5000mm - 3306 = 1694mm.
Could someone please show me how to add this option to the dynamic block?
dmfrazier
I would think you can accomplish this with dimensional constraints.
