Dynamic block with too many anchor points
boris.z
boris.z
when i open a dynamic block with different Visibility states, when i put it into the drawing and select it, i can see all the grips of the other visibility states. They all work like an anchor points. if there is a lot ot visibility states is bery difficult to work with this dynamic block.
Any idea how to fix?
i'm sorry for my english.
Libbya
If you want specific grips not to be visible in a specific visibility state, them make the associated *parameter* invisible in that state.
boris.z
Hi thanks for the response. They actualy are not grip of some parameters, but are the grips of the lines and arcs of the other "Visibilitys status " in that Dynamic block.
for example, when i import the Vehicles dynamic block from the Architectural Pallet (by defaut) it must have just the grip of the visibility status, instead when i select the block i can see all the grips of the lines and arcs of the other visibility status.
I suppose that i have to change some Variable...
Libbya
Why make the people you are asking for help guess at what you're talking about?  Post the block.
h_s_walker
At the command line type OPTIONS.
Now make sure the highlighted setting in the image below is not ticked
Howard Walker
Left Handed and Proud
boris.z
