Dynamic block with Lookup to change color
jk1173
jk1173
I am having a confusing issue in that the block stretches both vertically and horizontally and arrays as intended.  The color changing of the hatch is hit or miss.  This block was initially started with the help of Libbya several years ago, but I have recently refined it some.  The initial block had been able to have the hatch color ByBlock or 252.  I add a 3rd option and that seems to have broken it.  If I switch between the colors, it will only switch to 2 of the colors, and randomly picks which 2 to get stuck on.  Any help?
Jared - Sr. CAD Technician
Words to live by: If it ain't broke, you're not trying hard enough.
Julio_Soto
I think I found your problem. In your double lookup the property should be "CMU-252". It shows "CMU-Color" which is a visibility state that does not exist
jk1173
That did it - it just needed another set of eyes to look. Thanks for the help - works perfectly now.
