Dynamic Block with Array
darlon
darlon
Hi friends,
I'm trying to make a Dynamic Block of a Venetian, but I can not make the fins is reproduced to increase height. I believe I need to use the Array, but I can not. Could you help me?
Thank you
Libbya
Like this (see attached)?
darlon
Just that Libbya. Genial. Do you just add DISTANCE1 with ARRAY?
Libbya
Yes and I made it chained in properties.  The reason for the chained property with the array is to get the correct start distance.
darlon
Perfect. Thank you very much friend. I'm not a expert with AutoCAD, but if I can help you in any question...
