Dynamic Block - Variable constraints and fixed values - is this possible?
williamt7RZKF
williamt7RZKF
Good morning Hive Mind,
I'm working a developing a dynamic block for cut parts that are used in shipbuilding.
what I'm trying to do is make a bracket length proportional to the depth of the web of the cut part.  but with a fixed minimum value.
The rule is simple, its bracket length = 1.5x the depth of the web, so a 100mm web depth would give a 150mm bracket length. the issue is the bracket length cant be less than 100mm. for example when you have a 50mm deep web the rule would state that the bracket length would be 75mm, which would not give enough weld attachment.
I have started with a list option on the bracket length so it can't be smaller than required, but I would like to add little more intelligence to the block.
please see the screen shots for an instance where it is used, the current dynamic block, and the two areas that I would like to communicate to each other.
there are several other issues with but I'm stumped on this one at the minuet
Thank you for any hints and tips
Will 
CGBenner
@williamt7RZKF
Welcome to the Community, Will.  Thank you for the detailed question and for sharing the file for the experts to look at.  Good luck!
Chris Benner
j.palmeL29YX
For the bracket length I'd use a value
Bracket_length=max(1.5*web_depth,100)
Jürgen Palme
j.palmeL29YX
Some suggestion:
BTW: A lot (all?) of your construction lines may/should be deleted. You don't need it.
An example result attached.
Jürgen Palme
williamt7RZKF
Good morning Jürgen,
thank you very much for your solution, it works perfectly. as I'm just getting started on Dynamic blocks and constraints, it look any constraint could be written in the same format as an excel calculation, would this be correct?
thank you also for your suggestions, I have added them in to the dynamic block.
Hope you have a good week.
Will
j.palmeL29YX
... constraint could be written in the same format as an excel calculation, would this be correct?
F1 (Help):
Use Operators in Expressions
Dimensional constraint parameters and user variables support the following operators within expressions:
Operator Description
+ Addition
Subtraction or unary negation
Floating point modulo
Multiplication
/ Division
^ Exponentiation
( ) Parenthesis, expression delimiter
Decimal separator
Note: With imperial units, the Parameters Manager interprets a minus or a dash (-) as a unit separator rather than a subtraction operation. To specify subtraction, include at least one space before or after the minus sign. For example, to subtract 9" from 5', enter 5' -9" rather than 5'-9".
Understand Precedence in Expressions
Expressions are evaluated according to the following standard mathematical rules of precedence:
  1. Expressions in parentheses first, starting with the innermost set
  2. Operators in standard order: (1) unary negation, (2) exponents, (3) multiplication and division, and (4) addition and subtraction
  3. Operators of equal precedence from left to right
Functions Supported in Expressions
The following functions are available for use in expressions:
Function Syntax
Cosine cos(expression)
Sine sin(expression)
Tangent tan(expression)
Arc cosine acos(expression)
Arc sine asin(expression)
Arc tangent atan(expression)
Hyperbolic cosine cosh(expression)
Hyperbolic sine sinh(expression)
Hyperbolic tangent tanh(expression)
Arc hyperbolic cosine acosh(expression)
Arc hyperbolic sine asinh(expression)
Arc hyperbolic tangent atanh(expression)
Square root sqrt(expression)
Signum function (-1,0,1) sign(expression)
Round to nearest integer round(expression)
Truncate decimal trunc(expression)
Round down floor(expression)
Round up ceil(expression)
Absolute value abs(expression)
Largest element in array max(expression1;expression2)
Smallest element in array min(expression1;expression2)
Degrees to radians d2r(expression)
Radians to degrees r2d(expression)
Logarithm, base e ln(expression)
Logarithm, base 10 log(expression)
Exponent, base e exp(expression)
Exponent, base 10 exp10(expression)
Power function pow(expression1;expression2)
Random decimal, 0-1 Random
In addition to these functions, the constants Pi and e are also available for use in expressions.
Jürgen Palme
