parameters ... in Autocad. Looks the same as in Inventor.
Yep. This "Parametric" (since ACAD 2010) is very similar to the geometric and dimensional constraints in Inventor. There are some differences to Inventor (e.g. in AutoCAD you can not use reference parameters in expressions, in Inventor you can; and some other small differences too), a big difference: in AutoCAD you can use parametric in the 2D environment only (just as Dynamic Blocks).
"min" and "floor", What are these and what do they do in the formula?
The min function returns the smaller element of two values (which are separated by a ";" )
The floor function returns the value down rounded to the next smaller Integer.
For more details how to use Parametric in AutoCAD and especially in Dynamic Blocks here is IMO the wrong thread.
But no problem if you have further questions.
Jürgen Palme
