Announcements
Community notifications may experience intermittent interruptions between 10–12 November during scheduled maintenance. We appreciate your patience.
Dynamic block "visibility" with "attdef" error
I have multiple Block/ object with atttribute defination, i use block dynamic block, visibility to combine to make multiple option, but finally, it only change the normal opject but attdef object keep the same.
Other way, block 2 times, block (attdef object, normal object), then block 1 more time for visibility block, then i cant change the value of attdef.
Help me for that issue.
Libbya
You've done both of the two most common mistakes when using attributes in dynamic blocks.  First, each attribute must have its own unique tag.  You have multiple attributes with the same tag (e.g. MATCHLINE).  Second, in order for the attributes to work properly with dynamic parameters/actions, each must have the property locked = YES.
Here's how I would do it.  No visibility states, just flip and rotate.
