Dynamic block problem
I have received this block within survey plan. I'm trying to edit it, but no objects appear in block editor. When I do "select all" it shows "no selection". Does anyone have an idea what's up with this block?
Best regards
vinodkl
Hi @Anonymous
What you seeing in block editor is true. The block doesn't contain any elements inside it. It could be like this that the block did contain few attributes which you are able to see outside the block editor, but these attributes might have been deleted inside the block editor by someone before you could get it. A thing to know is that if any edits are done to attributes they don't reflect the changes until the attributes are synced using the command "ATTSYNC" outside the block editor. So try inserting a new copy of the block using the command "INSERT" and then you would see that the block would be completely empty and you don't see the attributes anymore🙂
when inserting a new block you can see there is nothing preview since the block is emptywhen inserting a new block you can see there is nothing preview since the block is empty
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
I see.
Thank you.
