Dynamic block - horizontal contraint
Hello, I'm trying to create these dynamic block but I cant get it to work like I would like to. The box needs to move horizontally and while doing that the other arm that is attach  needs to rotate but lower part needs to stay at that location. Any recommendations on how to achieve that?
Thank you.
h_s_walker
Post the drawing so we can have a look at what you're trying to achieve.
Howard Walker
Left Handed and Proud
Sorry I thought I did but here it is.
h_s_walker
I'm busy at work at the moment. HOWEVER, take a look at the attached drawing. I've put a block in your drawing called folding doors. If you take a look at how that works and fits together I believe it does what you want your block to do.
The XY parameter is in there because it can constrain movement to either horizontal or vertical. Take it out and see how the block breaks without it.
Howard Walker
