Dynamic block height no modify
Hi everyone I have some problems with my dynamic block that I trying to creat, the problem It's when I Insert the strech's parameters In the draw and when I Insert measures In the lookup this no modify the height, It's a door what I trying to creat with different measures and I don't know why no change the height. If someone knows the answer I'll be grateful to him.
h_s_walker
Welcome to the Forums
Post a drawing with the block in it, so we can have a look at it.
Howard Walker
Left Handed and Proud
I have recorded a video where I show the problem that I had, but suddenly when I was drawing noticed the trouble already gone. But the new problem is the door handle remains in the same point, it doesn't go up. I tried to correct it with constrains but it doesn't work. The certainly is I don't know much about constrains so If someone can help me with this too, I'll be grateful.
That is the new problem.
I think I got to change the version of my autocad.
neaton
Add another stretch Action to the height parameter that includes just the door handle. Change the distance multiplier to 0.5 so it stretches half the distance of the height. Remember Distance parameters can have multiple actions attached to them.
Parameters and Actions haven't changed since they were introduced in 2006 and Parametric constraints were added in 2010 and haven't changed so you don't need a newer version of AutoCAD.
Using both actions and constraints in the same block can cause some unexpected results so try to use just one or the other until you are more familiar with the limitations of each type.
Libbya
If you want a realistic representation of the door handle, it shouldn't go up when the door height is increased.  In real life, the height of the door handle is consistent regardless of the overall height of the door.
thank you so much finally I figured it out for your help. I didn't know I could add more stretch to the same block.
Yeah, that's right. But when I was drawing with dynamic blocks I was testing and I noticed that the Door handle doesn't moved and the same happen with a window I drew and I added the same parameters but the parant didn't move at par. Now I resolved the problem. Thank you so much.
