I have a dynamic block of a door which uses stretch actions to adjust thickness of door frame and adjust width of door leaf. This was based on user input, i.e. you would input size of door @ 838 and the the door opening and leaf would size to that, same for frame thickness. However recently it now displays as 0.000 when selected (previously it used to display the current door size) and you can only adjust by dragging and snapping or if you input whilst dragging it extends the dimension in that direction by your input i.e. if you input 50mm when dragging outwards on 838 door then it will resize to 888mm door width.
I haven't changed anything on the block so am thinking that a setting has changed somewhere, any suggestions?
This is what it is like now, used to be you would input desired door width here and it would resize accordingly. As you can see if i type in desired door width now it would add this to current door width!
